comment_4402
Voici ce qu'il faut faire pour accéder aux fonctions cachées de l'ordinateur de bord sur une BMW E46..
En Anglais mais je traduis tout ça et je fais un nouvel article :lol:
Avis à BBphoque M s'il veut essayer ;)
Instructions to access the hidden OBC functions:
1. Hold Trip Reset while turning ignition key to on position
2. OBC should show "Test"
3. Use Trip Reset to select function 19.0 that unlocks all the features
3. Wait for display to show "Off"
4. Depress Trip Reset for 1/4 second and release it
5. With no delay press Trip Reset several times to select one of the following functions
BMW E46 On-Board Computer (OBC) Hidden Codes
nr example description
1 Car Engine and cluster data
1.0 46nnn Chassis nr/VIN serial number (last 5 digits)
1.1 4nnn K-number
1.2 690236 Cluster Part #
1.3 045210 Coding (04)/diagnosis (52)/bus index (10)
1.4 1200 Week (12)/year of manufacture (2000)
1.5 09_160 Hardware (09) and software # (16.0) of cluster
1.6 Not used
1.7 04__44 CAN-version (04) KI-revision index (44)
2 (test) Cluster System Test - Activates the gauge drivers,
indicators and LEDs to confirm function
3 SI Data
3.0 1098 Used fuel in liters since last SI (Service Inspection)
3.1 0231 Periodic inspection days; elapsed days (since last SI)
4 Momentary Consumption
4.0 0145+ Instant fuel consumption - 0145=14.5 liters/100km
4.1 0018 Instant fuel consumption - 0018=1.8 l/Hour
5 Distance Gone Consumption
5.0 082 Average mileage; 082=8.2 liters/100km
5.1 0536 Calc. km to refuel (momentary distance to go)
6 Fuel Level sensor inputs in liters
6.0 109330+ Fuel level averaged; Left half sensor input=10.9 liters; Right sensor input=33.0 liters
6.1 0439+ Total tank level averaged; vlgs 6.0: 10.9+33.0=43.9 liters
6.2 0442+ Indicated value (44.2) and tank phase
7 Temperature and Speed
7.0 021+ Coolant/Engine temperature (2.1C)
7.1 130 Ambient/Outside temperature - chg met 5 pts. 125/130/135
7.2 + Engine speed / Current RPMs 1/min
7.3 + Vehicle speed / Current Speed in km/hour
8 Input value in HEX form
8.0 1d0+ System voltage ADC-Value Hex code
8.1 26C33C+ ADC Values HG left/HG right
8.2 0000 ADC Value brake degradation sensor (000=o.k.)
8.3 18C ADC Value outside temperature
9 Battery
9.0 140 Battery Voltage - 140 = UB 14.0v
9.1 242013+?
9.2 074_78+?
9.3 0011+?
10 Not used
11 Not used
12 Not used
13 GonG Gong Test
14 Not used
15 Status cluster I/O-ports (bit codes) 0=low; 1=high
1st-belt contact, seat belt fastened=0; 2) ignition lock contact, key inserted=0; 3) door contact, door open=0; 4) clock button pressed=0; 5) SI reset=0, for reset=0; 6) EGS transmission failure=0
Status Digital Outputs (bits) 0=inactive, 1=active
1) Gong output; 2) Brake warning lamp; 3) Low fuel warning lamp; 4) EGA lamp; 5) seat belt lamp; 6) manipulation dot
16 Not used
17 Not used
18 Not used
19 Lock Status; unlocks functions in range 3-18
19.0 L-On/L-Off Unlock: press button when "L-Off"
20 Not used
21 Software Reset; reset OBC settings
00 End of test
  • 3 mois plus tard...
comment_16722
mieux en français
1.0 Un numéro du châssis
1.1 K-Zahl Tacho
1.2 numéro de pièces
1.3coder -, diagnostic -, l'indice d'autobus
1.4 date de fabrication KW/J
1.5 état de logiciel et
1.6 facteur de moteur de nombre de cylindres de statut d'injection
2.0 Essai de système de voiture familiale
3.0 Service intervalle base du calcul en litres
3.1 nombres des jours jusqu'à l'inspection de temps
4.0 Consommation momentanée dans l/100km annonce z.B.0154=15,4l
4.1 consommation l/h
5.0 Consommation de portée dans l/100km
5.1 portée momentanément en km
6.0 contenu du réservoir moyen p. ex. 123321 = 12,3links 32,1 à droite
6.1 contenu du réservoir total p. ex. 0652 = 65,2 l
6.2 valeur d'annonce à la jauge à combustible et dernier nombre si 1 alors les
deux donneurs, annonce OK unplausibel=keine avec 2 erreurs de donneur
avec 3 ti signal
7.0 Température du liquide de refroidissement (dans °C)
7.1 température extérieure
7.2 régime moteur momentanément momentanément
7.3 vitesse momentanée momentanément
8.0 Représentation hexadécimale des valeurs de 7.0 7.3
9.0 Tension de réseau de bord en volts
10.0 Codage national
11.0 Codage d'unité
N'occupe pas 12.0
13.0 Essai
14.0-14.4 mémoires d'erreur avec 000000 pas d'erreur stocké 15.0 -
18.0 ne prouve pas
19.0 verrouillage/de Ent- des fonctions d'essai 3-20 annonce saute
sec. Rhytmus des I_on sur des I_off ouvrir : Pour une annonce des
I-off clé appuient sur fermer : Après l'abandon des fonctions
d'essai automatiquement
20.0 facteur de correction consommation formule pour facteur de
correction : Verbr indiqué. le X 1000/consommation déterminée =
facteur par la pression sur la clé de voiture familiale commence
l'ajustement des postes des des nombres commence de 0-9 à changer si
le nombre correct allume clé presse
20.1 réglage du poste dedécimale
20.2 réglage des 100 et 1000er la place
20.3 stockage et annonce eingeste
  • 10 ans plus tard...
comment_671328
J espère remporter le championnat du déterrage avec celui la ;-) Pour compléter le sujet avec l instruction en français, pour accéder aux fonctions de test, il faut 1-rester appuyer sur le bouton de mise à zéro du compteur kilométrique jusqu à apparition du menu 2-aller jusqu au menu num 19 en appuyant 19 fois sur le bouton 3-attendre que clignote test on - test off et appuyer pour activer le menu 4-aller sélectionner la fonction désirée http://youtu.be/p1U0X17yu_I A noter que cela fonctionne en roulant mais que je vous conseille de faire les manipulations a l arrêt par mesure de sécurité! :)
