Impossible de désactiver le DSC...
Il y a aussi jphughan qui dit l'avait désactivé et réactivé... Il ne parle pas de code.
"UPDATE!!
Yep, there's a coding option that can prevent you from turning off DSC. It's in the M3DSC module and it's called ABSCHALTBARKEIT_DSC (translation: shut down DSC). By default it's set to aktiv (i.e. you're allowed to shut down DSC), but when I switched it to nicht_aktiv and started my car, lo and behold, the DSC Off button didn't work anymore. Switched it back and everything was normal.
I imagine the M School cars might have some physical device that accomplishes the same thing by intercepting the signal from the DSC Off button to the DME so they don't have to deal with coding, but coding is probably the issue on the OP's car. Too bad you're not local or I'd check out your coding for free. In terms of your options, you might be able to take it to the dealer and request a software update, which typically resets al
  • 4 mois plus tard...
bonjour as-tu régler ton problème j'ai la même chose que toi et la voiture vient d’Allemagne...
