besoin d'aide pour montage pare choc csl
Voilà la liste complète des différences :
- Engine block (supposedly picked from the least flawed cast) – The blocks have the same part numbers as M3, Z4, but the full short block is a différent part number 11007833675
- Engine head (exhaust valve and intake/exhaust cams - longer duration, same lift) – intake cam shaft 11317835041 exhaust cam shaft 11317835043 Exhaust Valve 11347833676 (30,5/5,95mm) – the valve springs are exactly the same
- Intake plenum (carbon airbox as we like to call it) Air Collector 11617833496 filter 13727838625 The other half of the carbon box: 11617833497 and control unit 11617833498 all the other ducting 11617833646; 11617833645; 11617833648; 13717896774 intake grill 51117895883
- Extractors/Headers (same as post 2005 M3s and Z4) 11627833500; 11627833643
- Cat converter (200 cell) 18307833673
- X pipe, resonators (thinner material - slightly lighter) 18107833503
- Rear muffler - slightly lighter 18107833504
- différent ECU - 25% more capacity 12147837328; 12147834982
- différent SMG control unit program 23607837731
- Pseudo Alpha N engine management (delete of MAF, but still runs a MAP sensor, and air temp sensor 13621739510- debate as to whether this is just for idle control however) MAP sensor part number 13627833561
- différent traction control system with M track mode on steering wheel (much like the DCT mode in new E9X series)
-différent ABS control program
- Shorter steering ratio 14.5:1 (compared with 15.4:1 on M3) 32132282647 (same steering rack as the M3 CS)
- Front bumper (carbon fiber with incorporate bumper support) silver grey 51117896820 Sapphire Black 51117895950
- Roof (carbon fiber) 41007895382;
- Rear diffuser (carbon fiber) - the bumper is the same as M3 so is the carrier – silver grey 51127896832 Sapphire Black 51127895985
- Boot lid (Moulded sheet plastic - it's not fiberglass people, it's much harder and more rigid) 41007895884
- Rolled rear fenders to accommodate wider rear rims. Bare Full Body Skeleton for CSL 41007895934 (part numbers for the rear fenders are the same as M3, but the CSL comes from the factory with ROLLED rear fenders)
- différent wheels (NOT magnesium, cast aluminium) made by BBS 36112282650; 36112282999
- Suspension and spring (sachs, shorter spring and différent damper and rebound rates) fronts 31312282505; 31312282506 front bump stop 31332282508 rear 33522282507, rear mount disc (CSL specific) 33532282503; bumper stop 33532282509
- différent rear lower arm - aluminium with spherical joint 33322283074
- différent front king pin (hub) for wider front track 31212282855; 31212282856
- larger front sway bar (hollow) 30.8mm 31352282655
- larger rear sway bar 22.5mm 33552282681
- larger front brakes (345mm) 34112282445; 34112282446 brake carrier 34112282619
- larger rear brake caliper piston 34212282857; 34212282858 (same as M3 CS)
- Pilot sport Cup Tyres 85452536738; 85452536740
- Lighter rear glass 51317895441
- Recaro SPG Type front seats 52100031830; 52100031831; rails 52107895957; 52107895958
- Lighter rear seats (4 seater rather than 5) 52207896809; 52207896800 rear console 52207896297
- Lightweight through load facility 52207896929; 52207896930; 52207896807; 52207896808
- Paper/Honey combe boot floor COVER (yes the infamous cardboard floor) 51477895990
- Carbon door cards and rear panel 51417895581; 51417895582; 51437895579; 51437895580 Door handles 51417896919; 51417896920
- Carbon centre console 51167896359
- Alcantara steering wheel 32342282502
- Alcantara hand brake lever 34412282662
- 4 rather than 6(or 8 if equiped) airbags
- NO INTERIOR SOUND DEADENING
- No bonnet heat shield (same aluminium bonnet as M3)
- Optional Radio and aircon
- Lighter battery (same as the Mini Cooper S battery) 61218377139
- Lighter microfilter housing (bottom part 64 31 7 895 937 1.050 kg, housing 64 31 7 895 939 1.630 kg)
Unconfirmed differences:
- less under carriage undercoating
- extra welding points to châssis
Source : http://www.clubcsl.com/index.php/m3csl/6-m3-csl-differences
  • Réponses 63
  • Vues 15.2k
@zarmoth ...
Sa sert a rien de comparer les prix par de rien et va a ta concession commande toutes les pieces pour monter un m tu sera surprit de l adition ...
Modifié par Cédric91
Bien vue gilles je modifie ça fin de semaine ;)
